I'm about to reinstall my GPU's back into my system after installing my water blocks. I want the setup to kind of look like the first attached picture where both of the tubes from the cpu block go downward. However the EK terminal i bought (EK-FC terminal DUAL Parallel) (the second attached file) doesn't look like it can support this feature... however to be honest this thing kind of confuses me... is there any way to get that kind of look with this terminal??
My current Rig (Memphis) --> http://pcpartpicker.com/p/jQYWpg
https://linustechtips.com/topic/465937-sli-liquid-cooling/
I see what you are trying to do, what are the gpus you are water colling? and are the block Ek?
https://linustechtips.com/topic/465937-sli-liquid-cooling/#findComment-6252268
the only way i know how to do that .is from the gpu to the cpu use smaller ID tubes so the restriction  is nearly equal but it looks funny rest of loop 5/8 or 1/2  then the tubes for the cpu are smaller . or  if you have a high restrictive cpu block then it doesnt matter use the same  tubing .if not try it and see if cooling is not what you want and redo it then
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
https://linustechtips.com/topic/465937-sli-liquid-cooling/#findComment-6257244
