Router / modem help
Go to solution Solved by Blade of Grass,
Just a router with WAN connection :)
With a budget like that you can get pretty much whatever you want.
All of the manufacturers have top of the line models in that price range, so take your pick:
  • Netgear Nighthawk R8000
  • ASUS RT-AC3200
  • D-Link DIR-890L
  • Linksys EA9200
Sup dudes,
I am getting a upgrade in my interwebs next week and i want to have a router to work with it. What do you guys recommend?
My network speed as advertised will be : 160 mbits down and 10 mbits up. Cable. Atm i have ADSL 16 mbits down and 0,7 mbits up
My budget around 200-300€.
Must haves:
QoS
Dual band or tri band
2,4 hz and 5Ghz
Good range
Maybe a alien UFO
have fun searching :D
Thanks in advance
CPU: Intel I7 4790K 4.8 Ghz || Mobo: ASUS ROG Maximus Hero 6 Z87 || Ram: Corsair Vengeance 16 GB 1600 Mhz || GPU: ASUS GTX 980 Ti STRIX || Storage: 2 x SSD Samsung 840 EVO 250 GB RAID 0 HDD Western Digital 1 TB Black || PSU: Corsair AX 860 watt || Cooling: 2 x AF 140mm (front), 2 AF120 Blue LED (bottom and back), 2 SP120 (top on radiator) ||  CPU cooler: Corsair H100i GTX || Case: Corsair obsidian 750D <3 <3 <3
https://linustechtips.com/topic/465539-router-modem-help/
Do you need both a modem and router or just a router?
https://linustechtips.com/topic/465539-router-modem-help/#findComment-6247065
  • ASUS RT-AC3200
  • D-Link DIR-890L
  • Linksys EA9200
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/465539-router-modem-help/#findComment-6247102
All of the manufacturers have top of the line models in that range, so take your pick:
  • ASUS RT-AC3200
  • D-Link DIR-890L
  • Linksys EA9200
Thanks for your help :D
https://linustechtips.com/topic/465539-router-modem-help/#findComment-6247106
I'd say one of these:
TP-LINK Archer C7. Wireless ac1750. Buy it and put the gargoyle firmware on it. I've got experience with gargoyle running on the older N600 version of this and it works amazingly.
http://www.amazon.co.uk/TP-LINK-Archer-C7-Wireless-Gigabit/dp/B00CEB53MS/ref=sr_1_1?ie=UTF8&qid=1444602311&sr=8-1&keywords=tp-link+archer+c7
gargoyle-firmware.com
Leaves you money for something else too! :)
edit: It may have QoS already without gargoyle but I can't remember. Haven't used TP-LINK's stock stuff much
https://linustechtips.com/topic/465539-router-modem-help/#findComment-6247130
I'd buy something proper instead of consumer stuff...
Å mikrotik or ubiquiti router + a ubiquiti AC accesspoint
Network/Homelab build log Main PC: "Aqua Blue"  Server: 15TB+ "Blue Lightning"
3900x, 32GB RAM @3200mhz, RTX 3090, 2.5TB+ SSD Storage, 4x2560x1440 monitors
Samsung Galaxy Z Fold2 5G, +2x Note 9
https://linustechtips.com/topic/465539-router-modem-help/#findComment-6248014
