I'm getting a new desk so I want to get a new power extender (not sure if that' the correct name for them, the splitter for mains)
I live in the UK so obviously need to be the UK mains socket.
I'm looking at this one at the moment but does anyone have anything better/cheaper?
http://www.amazon.co.uk/gp/product/B006HFME4M?ascsubtag=pfb-NUL-3-2-14377799974728x&ref_=pfb_NUL_3_2_14377799974728x&tag=hydfbook-21#Ask
CPU: FX-6300 GPU: Sapphire R9 380X MOBO: Gigabyte 970A-DS3P RAM: Corsair Vengeance 8GB PSU: XFX XTR 550W CASE: Zalman Z11 Plus SSD: Samsung 840 Evo
17 years old, PC Enthusiast for 3. Be gentle with me, I'm only young.
https://linustechtips.com/topic/465251-good-power-extender/
A power extender is a power extender, there isn't much to discern one from the other AFAIK.
That one looks pretty good, and fairly cheap. Surge protection is a big plus IMO.
Other systems I've built:
https://linustechtips.com/topic/465251-good-power-extender/#findComment-6243775
Guess so, don't really want cheapen out and end up with it breaking instantly or worse blowing up.
Definitely want the Surge protection
http://www.amazon.co.uk/Masterplug-SRPTU82PB-Charging-Protected-Extension/dp/B006HFMEMO/ref=sr_1_8?&ie=UTF8&qid=1437735619&sr=8-8&keywords=plug+extension
there is this one that supports ethernet proctection as well
https://linustechtips.com/topic/465251-good-power-extender/#findComment-6243787
Both are good, I can't really advise you on one or the other :)
https://linustechtips.com/topic/465251-good-power-extender/#findComment-6243801
