Yes you can. Without a doubt.
I had  GTX 660 with a power hungry AMD cpu on a 450watts and such without problems for years.
There will be people here saying you'll need more for "headroom", don't believe them because you don't need that.
https://linustechtips.com/topic/464938-will-my-psu-be-enough/#findComment-6239817
My rig
FX-6300
8 GB DDR3 1600 MHz
450 W PSU
Will I be able to run a gtx 950 with that psu?
Thank you
It completely depends on the quality of the PSU.
If we assume it's decent, we can assume that you shouldn't have any problems.
Sig under construction.
https://linustechtips.com/topic/464938-will-my-psu-be-enough/#findComment-6239818
My rig
FX-6300
8 GB DDR3 1600 MHz
450 W PSU
Thank you
What Brand is it?
500w is recommend.
https://linustechtips.com/topic/464938-will-my-psu-be-enough/#findComment-6239820
should be fine as long as youre not overclocking too high, the 950 isnt a very power hungry card
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/464938-will-my-psu-be-enough/#findComment-6239821
I had  GTX 960 with a power hungry AMD cpu on a 450watts and such without problems for years.
You've had a GTX 960 for years?
https://linustechtips.com/topic/464938-will-my-psu-be-enough/#findComment-6239825
My rig
FX-6300
8 GB DDR3 1600 MHz
450 W PSU
Thank you
Psst follow your own topics.
Also a GTX 950 takes little power. 250W would be enough wattage but you definitely want a good quality PSU. Check out the PSU whitelist in my sig for good options.
https://linustechtips.com/topic/464938-will-my-psu-be-enough/#findComment-6239902
I meant to say a 660 and to state that even that card uses more power.. i'm getting sleepy
Okay, that makes a lot of sense. And the 660 has a TDP of like 140w? I have a friend who bought a PC with a 4770 and 16GB of RAM and a GTX 660. I'm still trying to get him to upgrade and get a relatively decent graphics card.
https://linustechtips.com/topic/464938-will-my-psu-be-enough/#findComment-6239910
