So I have been using a logitech mouse for about 6 years but they fail & every click eventually becomes a double click, which basically makes me buy another one. The reason i keep buying this mouse is cause i have muscular dystrophy & my hand is strong enough to press the buttons on this paticular mouse which is the logitech m305. The mouse has been discontinued & finding them is getting harder, now logitech made the m325 to replace the m305 but it's really hard to press.
https://linustechtips.com/topic/463896-need-a-reliable-small-mouse/
I would recommend this mouse here http://www.newegg.com/Product/Product.aspx?Item=N82E16826197059 Not exactly affordable, but its comfortable and lasted me awhile.
If your looking for animals.... http://www.petsmart.com/live-pet/live-small-pets/cat-36-catid-700004  (I had too......)
The M165 doesn't seem to need much pressure to activate the buttons, but I really can't judge if is as soft as the M305 or not since I never tried that mouse.
Comparing it to my g402 it does feel like the button is heavier, the g402 is a little easier to press.
Mystery is the source of all true science.
have you tried the microsoft 3500/4000 wireless mice?   they're about the same size as the logitech m305
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
  • 4 weeks later...
Hey, I just tried a logitech m90 mouse, and the buttons are feather like, barely need any force to press them, I think you could use this mouse.
