Phone Virus Help
Go to solution Solved by The Official Czex,
This is a four part question  (sorry)
1.  Can a phone get a virus?  (like a pc).
2.  If the first question/ one is a yes, how do i clean my phone fully so it will kill the virus?  (im willing to lose all previous data/ memory if i need to).
3.  Ignore if one is no.  If my phone does got a virus, how can i protect/ save my data/ memory on the phone?
4.  Ignore if one is no.  For future, how do i prevent this from happening?  (what causes the virus and how do i stay away from them on my phone).
If confused by what i mean
"data/ memory" means whats on the phone and/or whats saved on it.
Backstory
Earlier i had a phone for texting.  One day when i was not using it for texting or keeping me busy when im bored, i put it away and lost it (or just forgot where it was).  Now im back to wanting to use it once again for texting but am afraid that my past has caused this phone to get a virus.
Android can get viruses. IOS can as well, just not as easily. AVG has an app.Don't download sketchy apps and programs.
3.  Ignore if one is no and/ or two is lose data/ memory.  If my phone does got a virus, how can i protect/ save my data/ memory on the phone?
Backstory
The phone
Iphone 4
Edited by Made In Canada
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/463894-phone-virus-help/
Backstory
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/463894-phone-virus-help/#findComment-6226146
Yes. It is less common however.
I have not had anything, but I know avast has an antivirus for phones. You can go into the options and perform a backup and reset.
Google backs up your photos, any games or apps you have purchased are saved, and can be downloaded again. These are usually put on an SD card, and this SD card can be connected to your PC using a microSD card reader. You can go into the options and perform a backup and reset.
The "virus" will usually just come from a fake popup on the browser telling you that you have a virus, and then it tells you to manually install something sketchy.
https://linustechtips.com/topic/463894-phone-virus-help/#findComment-6226160
Do i just download the AVG app and run it?  Will it find previous viruses or just new ones?
-Made In Canada
https://linustechtips.com/topic/463894-phone-virus-help/#findComment-6226169
All viruses. You can also go in and find any files that look sketchy to you and delete their asses as well as any apps that have a non-reputable developer.
https://linustechtips.com/topic/463894-phone-virus-help/#findComment-6226198
1.  Do i just download the avast app and run it?  Will it find previous viruses or just new ones?
2.  Would'nt the SD card have the virus on it?
-Made In Canada
https://linustechtips.com/topic/463894-phone-virus-help/#findComment-6226202
Thank You!!!
-Made In Canada
https://linustechtips.com/topic/463894-phone-virus-help/#findComment-6226206
Thank You!!!
When your question is solved, you can "Mark as Solved" the post that helped you the most, so others can find it and get the information they need.  ;)
https://linustechtips.com/topic/463894-phone-virus-help/#findComment-6226238
