Hey guys.
I have the weirdest problem.
so what happens is I did some maintenance on my system by cleaning out the dust and so forth. When i was done i hade the strangest problem my pc sould just not POST. There is no post screen but the weird thing is is that when my pc is put on its side the pc would port and startup just fine. I disconnected and reconected all the cables, I went as far to take my whole pc apart and build it again with no luck.
Any help will be much appreciated.
Thanks guys
https://linustechtips.com/topic/463549-pc-post-issues/
Check for a loose wire in the Power supply connector to the motherboard header and the motherboard 4/6 pine power connector. Test by having the pc upright and gently "push" or wiggle slowly the wires going into the motherboard headers. BE EXTREMELY CAREFUL AS THIS IS A SHOCK HAZARD!  I will not be responsible for damage to the pc or you as a result of shock. Be careful as this could produce a surge to the motherboard and kill it or you could be shocked.
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
https://linustechtips.com/topic/463549-pc-post-issues/#findComment-6221878
