I am looking into building a new PC but need some help picking out the right parts (first time PC builder), Figured it would be easier and cheaper to build than buy. Bellow are what the PC should be able to handle
  • Programing
  • Graphic Design
  • 3D Modeling
  • A little bit of gaming
My budget is Under $800 CAD, but ill pay more for better Quality/Performance
So far I have put this together http://ca.pcpartpicker.com/p/yyfhHx
Thanks in advance and sorry if I posted this in the wrong section.
Update 1: I Upped my budget to $800 USD.
https://linustechtips.com/topic/463402-building-a-pc/
That, and you could go for a cheaper case. Maybe save up a bit and get a better i5? R9 380?
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6219387
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($57.62 @ DirectCanada)
Memory: Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory  ($49.98 @ DirectCanada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.94 @ DirectCanada)
Video Card: Sapphire Radeon R9 380 4GB Nitro Video Card  ($291.29 @ Newegg Canada)
Case: Silverstone PS08B (Black) MicroATX Mid Tower Case  ($44.99 @ Newegg Canada)
Total: $754.44
Generated by PCPartPicker 2015-10-07 22:08 EDT-0400
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6219410
Total: $754.44
Im Looking for a simple case for example the define S, simple outside and a great inside (cable management, space, etc.)
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6219473
Then buy a Define S. The NZXT H440 is nice too, but pricey. If you really want your PC to look good, might as well get a case you want.
The Laptop:
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6219482
Not sure about the price in Canada but the NZXT S340 is a clean looking budget case.
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6219487
Looks nice, but I was looking at the H440 and was wondering is there an case with similar design but with good air flow
Fractal Design R5.  Good airflow but a tad bit louder.  Temps aren't bad in the H440 tho.
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220042
Do you know of any case that's similar to the H440 but cheaper in price?
Define R4 and S340
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220121
$820
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($239.00 @ Vuugo)
Memory: Team Dark 8GB (1 x 8GB) DDR3-1600 Memory  ($53.69 @ Newegg Canada)
Storage: Corsair Force LS 240GB 2.5" Solid State Drive  ($88.88 @ Canada Computers)
Video Card: Gigabyte GeForce GTX 960 2GB Video Card  ($229.99 @ NCIX)
Case: Thermaltake Versa H22 ATX Mid Tower Case  ($48.50 @ Vuugo)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($79.99 @ Newegg Canada)
Total: $797.67
Generated by PCPartPicker 2015-10-08 00:14 EDT-0400
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220185
Yes but is the case is premium quality why not.
Because you are on such a tight budget, that spending extra is not an option... so you get a "premium" case and shitty core performance?  What kind of PC is this?  Looks good and does not perform, not the best way to build.  I would rather mount onto a piece of plywood if that meant a good jump in performance.
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220193
Since this is my first time building a PC from scratch, I really don't know that much about components.
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220218
If you have an i5 2400, and want to re-use it...
$410, just pick your GPU...
CPU: Intel Core i5-2400 3.1GHz Quad-Core Processor
Motherboard: MSI H61M-P31/W8 Micro ATX LGA1155 Motherboard  ($64.75 @ Vuugo)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($97.97 @ Amazon Canada)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($110.49 @ DirectCanada)
Case: Corsair 100R ATX Mid Tower Case  ($52.99 @ NCIX)
Total: $406.19
Generated by PCPartPicker 2015-10-08 00:33 EDT-0400
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220264
Total: $406.19
No I have to start from scratch
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220285
$820
Total: $797.67
The R9 380 seems to outway the GTX 960 because it has a better floating point performance.
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220302
$820
Total: $797.67
I made some modifications
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($74.98 @ NCIX)
Total: $779.45
Generated by PCPartPicker 2015-10-08 02:10 EDT-0400
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220660
Yeah, but it cost more.  I tried that config:  http://ca.pcpartpicker.com/part/powercolor-video-card-axr93804gbd5ppdhe
Total: $779.45
No HDD or SSD?  Do you have an old one?
That motherboard supports up to 1600MHz RAM.
https://linustechtips.com/topic/463402-building-a-pc/#findComment-6220670
