about 75% of the time when i launch a game such as csgo, i will get the error thread_stuck_in_device_driver. This has become a daily occurrence and i want to fix it. i already made a post on this, the "solution" didnt work.
i think its my graphics card. i have a sapphire radeon r7 260x
Athlon X4 860K, Sapphire Radeon R7 260X, Corsair Vengeance 8GB, Gigabyte GA F2A68HM-H, WD Blue 1Tb, EVGA 500w, Corsair Air 240
https://linustechtips.com/topic/463381-help/
Have you tried clean reinstalling the driver? like uninstalling them with a driver cleaner, before installing the newest version
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/463381-help/#findComment-6219184
no, what driver uninstaller should i use?
https://linustechtips.com/topic/463381-help/#findComment-6219189
Display Driver Unistaller
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/463381-help/#findComment-6219245
I haven't used any myself as the nvidia driver installer has an option to clean install, but a quick google search should yield some results.
My friend had a similar issue after testing an nvidia card in his system, when the drivers didn't play nice with the default amd drivers.
https://linustechtips.com/topic/463381-help/#findComment-6219250
