ok, crazy hypothetical question...
Go to solution Solved by typographie,
Could a 4-way SLI'd gtx 980ti with a custom loop do 4k surround monitors?
It really depends on the game. Three- and four-way SLI are incredibly inconsistent. Some games you get great scaling, and sometimes it's no faster than two cards.
Could a 4-way SLI'd gtx 980ti with a custom loop do 4k surround monitors? just curious, and also, what motherboard would you recomend?
my first build ^~^ cpu: core i5 6500
mobo: Asrock h110-itx
gpu: r9 380
8 gigs ddr4
psu: corsair cx 500
case:thermaltake core v1
https://linustechtips.com/topic/463242-ok-crazy-hypothetical-question/
If 4 Titan X's have a hard time doing it, then 980's will do worse.
Plus, micro stuttering at that point will make your life miserable, not worth it.
I wouldn't recommend 4-way SLI to anyone. It's not really stable.
Born too early to explore the galaxy, born too late to explore the seas, born just in time to make memes.
Hypothetically, if the 4 980s were powered by a sketchy power supply, they'd cause a fire and you'd have to evacuate your house. You'd then have the best surround setup at the best possible resolution - the real world!
/jk
How to create a strong password
Size does not matter; it's how you use it
You can run 4k sourround with 3 980tis, but youre gonna have to use fxaa, disable tesselation, ambient occlusion, depth of field and maybe some other advanced options to get good framerates in some games.
3 980 tis in sourround should be about equivalent to 1 regular 980 in 4k.
