I was looking at some specs on GPUs and the thing that i don't understand is the clock speed. Sometimes its like 80 mhz or so. Like the MSi GTX 960 OC and oc is overclocked but its only 1178 mhz and the Gaming 4G is 1241 mhz. Does the clock speed really impact the FPS? Like 10 FPS or so? Also, wich brand deliver the most power in the GTX 960 series?
https://linustechtips.com/topic/462822-gpu-clock-speed/
Don't buy a 960. Get a 380 instead or save up and get a 390.
With NVidia GPUs though, I like MSI and Asus for their coolers. If you just want a good GPU, EVGA makes good ones too.
Seriously though. If you're just gaming, get an R9 380 or 390.
EDIT- to answer your question on clock speeds, yes, it will impact gaming, but not too much. Higher is always better, but if it has a good cooler you can always up that clock speed anyway.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/462822-gpu-clock-speed/#findComment-6211079
No, with such a insignificant increase, like 80 MHz, the performance different is generally very minor.\
It is much lower than your expected 10FPS; realistically, anything in the range of 0~3 FPS.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/462822-gpu-clock-speed/#findComment-6211140
