I just bought a universal TV remote cause the other one broke, I used the auto find feature but I was only able to turn the volume up and down for the TV. In the instructions it said you have to search for a code, but I don't know the code number! (LG TV)
http://www.logitech.com/en-ca/product/harmony-remote-650?crid=60
the only universal remote I trust
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
where do I get the codes from
the remote can probably search for more codes
otherwise you need to google for the codes to the device
personally I would just get rid of that one you got and get a logtech harmony
work so much better and can probably find one for 30-40$
