I'm using the floppy as a 4-pin adapter for my fan to my power supply, but the end of the cable which is a 6-pin says "PERIF"
Do I plug it in to the PATA slot in my PSU? The only other option is SATA so I'm assuming it's PATA.
My Baby Girl ❤️CPU: Ryzen 7 3700X | Mobo: ASRock B450 Pro4 ATX | RAM: 2 x 8 GB DDR4 3200 MHz GPU: EVGA GTX 1070 SC | Case: Fractal Design Core 3500 | HDD: Seagate 1TB SSD: Adata SP900 512GB PSU: EVGA 650G 80+ Gold Full Modular | OS: Windows 10
https://linustechtips.com/topic/462802-help/
Are the cables even electrically compatible?
https://linustechtips.com/topic/462802-help/#findComment-6210874
Nope, I found out that I'm gonna need to get 4 pin to molex adapters. I wasn't paying attention that there were no pins on either of the cables lol.
https://linustechtips.com/topic/462802-help/#findComment-6210893
you need to show us pictures of the plug
you wont want to kill your PSU and your whole computer just because you plug them wrongly
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/462802-help/#findComment-6210894
