Hey guys,
So, this is my first build -- so don't be so harsh. (http://pcpartpicker.com/p/WhyK99)
I'm using a 1.2TB NVMe drive, 2 980 Ti's etc.. I've only plugged in 2 plugs to the PSU.. Am I doing something wrong?
1 PCIe cable is connected to both 980 Ti's, a "two in one" -- only 1 plug in the PSU
Then, I have the long one which is connected to the mobo, which makes for the 2nd plug to the PSU.
Is there something wrong here?
EDIT: 3 cables
Everyday build:
CPU: Intel Core i7 5960x - GPU(s): 2x EVGA GTX 980 Ti Superclocked+ ACX2.0+ (SLI) - Cooler: be quiet! Dark Rock Pro 3 - Motherboard: ASUS Sabertooth X99 - RAM: 32GB Kingston HyperX Fury Black DDR4 4x8GB (2666MHz) - Storage: Intel 750 Series 1.2TB + 4TB WD Black - Case: Corsair 760T White - PSU: SeaSonic 1200W 80+ Platinum Certified - OS: Windows 10 Pro - Wireless Adapter: TP-Link Archer T9E - Monitor: Acer XB270HU bprz - Keyboard: Corsair K70 RGB - Mouse(s): Corsair Gaming M65 RGB + Logitech MX Master - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/WhyK99 https://linustechtips.com/main/topic/474247-r8-my-build/
Weekend build:
CPU: Intel Core i7 5930k - GPU(s): 2x EVGA GTX 980 Ti Classified ACX2.0+ (SLI) - Cooler: NZXT Kraken X61 - Motherboard: ASUS X99-Deluxe - RAM: 32GB Crucial Ballistix Sport LT DDR4 4x8GB (2666MHz) - Storage: Samsung 950 Pro 512GB m.2 & 2TB Samsung 850 Evo - Case: Phanteks Enthoo Evolv - PSU: SeaSonic SnowSilent 1050W 80+ Platinum Certified - OS: Windows 10 Home - Monitor: Dell S2716DG 144hz - Keyboard: Corsair STRAFE RGB - Mouse: Corsair Gaming M65 RGB - Headphones: Sennheiser PC363D
http://pcpartpicker.com/p/YYK93C
https://linustechtips.com/topic/462795-psu-help/
@cortexcortex your pcpp link is broken
My Rigs:
Gaming/CAD/Rendering Rig
Case:
 Corsair Air 240 , CPU: i7-4790K, Mobo: ASUS Gryphon Z97 mATX,  GPU: Gigabyte G1 Gaming GTX 970, RAM: G.Skill Sniper 16GB, SSD: SAMSUNG 1TB 840 EVO, Cooling: Corsair H80i PCPP: https://au.pcpartpicker.com/b/f2TH99SFF HTPC
Case:
Silverstone ML06B, CPU: Pentium G3258, Mobo: Gigabyte GA-H97N-WiFi, RAM: G.Skill 4GB, SSD: Kingston SSDNow 120GB PCPP: https://au.pcpartpicker.com/b/JmZ8TW
https://linustechtips.com/topic/462795-psu-help/#findComment-6210791
link is broken
sorry, fixed
Everyday build:
Weekend build:
https://linustechtips.com/topic/462795-psu-help/#findComment-6210805
general rule is if it fits, it sits
side note, why do you have 2 mice in your pcpp link
Thanks, and also I liked both so I got them both :P
Everyday build:
Weekend build:
https://linustechtips.com/topic/462795-psu-help/#findComment-6210828
also why does he have so much money T^T
My Rigs:
Case:
Case:
https://linustechtips.com/topic/462795-psu-help/#findComment-6210850
