No, back up your Data ASAP and replace the drive!
I successfully hacked 127.0.0.1! Now I cant turn on my computer :/
6700K - z170 Pro Gaming - Samsung 850 Pro 256GB - WD Black 1TB - WD Green 3TB - External Hard drive 3TB - Zotac GTX 970 Amp! Core Edition - Fractal Define R5 - RM650 - Razer BW Chroma - Roccat Tyon Lasermouse
https://linustechtips.com/topic/462654-smart-failure/#findComment-6209086
I think you know what to do
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/462654-smart-failure/#findComment-6209138
"It can fail soon or in 2 years, it's mostly impredictable... It happens for a number of reason, random failure, shock (laptop are most likely to have this problem as you shouldn't move an HDD when it's running and changing your laptop positioning happens frequently), it can happen from overheating, not defragmenting (especially if you're drive is full as you need to keep 10 to 20% free on all HDDs in order for them to run correctly), it's also possible from wrong shutdown, hard reset or current interruption (battery dead) as the head will not replace itself on the start point where she is protected...
HDDs are the most common failure in PC (from my personal experience i had replace 4 in 3 PC in order to keep them running)"
https://linustechtips.com/topic/462654-smart-failure/#findComment-6209198
It won't do anything when I press F1, it's just frozen on this screen
take the drive out, and mirror the drive to a new one in an other system.
or take it to a store to do it if you dont have the tools or knowledge.
https://linustechtips.com/topic/462654-smart-failure/#findComment-6209512
