Yea that's a low end G31 chipset board not really designed with overclocking in mind. There's a silicone lottery on the northbridge as well for 775 that helps determine your overclock.
https://linustechtips.com/topic/462342-e7500-oc-problem/#findComment-6204938
what mobo you got?
your mobo may not be able to support that OC
also check your RAM speed
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/462342-e7500-oc-problem/#findComment-6204939
