first you bind the binds to your numberpad. then bind the g keys to the number pads.
Specs: i7-4790k with Thermaltake Water 3.0, EVGA GTX 970, MSI Z97 Gaming 3, Kingston HyperX 2x8 DDR3 1600Mhz, SSD Boot Drive/1TB HD, CM Storm Stryker, EVGA Supernova G2 750W
Peripherals: SS Rival, HyperX Cloud, G710+
https://linustechtips.com/topic/462114-setting-up-g-keys/#findComment-6201633
I have a G710+ and I never use the g-keys. If you're playing csgo with them then use the numpad I think it's more comfortable
https://linustechtips.com/topic/462114-setting-up-g-keys/#findComment-6201639
