Hi I was just curious and couldn't find anything definitive and wanted to know, I have a 8GB windows instal drive but also with an extra 3GBs of space, Can I put other files onto this drive or does it need to be exclusively for the Windows OS ?
u can 'TECHNICALLY" use it as storage as well, however, when you are installing os onto a pc, make sure to remove the files, or you may corupt the os. also, only, as a precaution, plug in the usb after you have thurned the pc ON, inorder to prevent windows from trying to install OS, with extra files
ah.. I was hoping to keep Drivers and OS specific tools on specific OS drives. But if that's the case I should just have a mass Drivers drive then. Oh well, Thank you for the info =)
actually, if you keep it on a separate directory, you should be fine. just don't put them in "install" or"boot" or anything like that...
I like Computer Stuffs. Have you tried unplugging it and plugging it in again? Automation Expert (Bots, scripts, etc)! Add me on Xbox Live: JollyPlanet449 And on Steam!: Baxtmann Wanshow.tips is a cool place too
yeah, heres an example
post-54578-0-76341100-1444086734_thumb.p
This is what my boot USB looks like, Can I just make a new folder with the OS specific drivers ?
The answer is yes, yes you can.
CPU: Intel Core i7-4790K | GPU: GTX 1080Ti | Case: Corsair 750D Airflow | Motherboard: ASUS Maximus Formula VI | RAM: 16GB Vengeance Pro | PSU: Corsair AX860
SSD/HDD(s): SAMSUNG 850 EVO 120GB, SAMSUNG PM830 256GB, SEAGATE 6TB | Optical Drive: Sony Optiarc AD-5280S CB-PLUS
