So this morning I already posted about this. I ran it a while at 4.7GHz at 1.255V and when I tested with both aida64 and OCCT temps would go up to 90 and more. (Not constantly but it would bounce up to like 90-92 then back down to 70 for some odd reason)
During cs:go gameplay it was ok but now after playing for longer than an hour temps would go a little too high to my likings.. 80°C
So I decided to turn it down to 4.6GHz at 1.220V but temps still go up to 90°C ... I'm officially lost now. Anyone know what's going on?
Gif during test: gif
SOLVED: So apparently I didn't adjust some setting or it got auto adjusted. My CPU input voltage was set at 1.8V, a friend told me 1.4V was like max so that was the problem of my super high temps after 30 seconds of benching. Back to overclocking and seeing if I can hit 4.8! :D
The Beast: CPU: i7 4790K GPU: EVGA 1080 SC Cooling: Dual NZXT Kraken x61 RAM: HyperX Fury 1866MHz Storage: SSD: 500GB Samsung EVO 840 + HDD: 1TB WD MOBO: Asus Z97 - a PSU: RM850x Case: H440 green-black Setup: Link PCPP: Link Evolution: Link
Gear: PS4 with custom skin // Astro A50 Xbox edition to fit colour scheme // Oppo PM-3 Planar Magnetic Closed Back Headphones // OnePlus One 64GB sandstone
Other stuffs: Acer aspire 128GB SSD 10GB RAM // MacBook Pro 13" 500GB SSD 16GB RAM // A 2009 iMac 21"
https://linustechtips.com/topic/460690-i7-4790k-oc-problem/
Background program? Try disable unnecessary program and see your cpu load
Intel i5-3570k @ 4.2Ghz, CoolerMaster Seidon 240m + Dual Corsair SP120 Silent Edition, Asus Strix GTX980, Corsair Dominator DDR3 C9 1600mhz 16GB kit, Samsung SSD 840 series 250Gb, WD 4TB HDD. Casing : Corsair Obsidian 250D, Astro A50 Gaming headset, Blue Yeti Microphone.
https://linustechtips.com/topic/460690-i7-4790k-oc-problem/#findComment-6182525
Background program?
The gif is from realtemp
What cooler are you using?
dark rock pro 3
https://linustechtips.com/topic/460690-i7-4790k-oc-problem/#findComment-6182534
dark rock pro 3
The Gif shows 100% load utilisation. Means something is running your cpu at top speed
Disable some program thats running at the background
https://linustechtips.com/topic/460690-i7-4790k-oc-problem/#findComment-6182552
Yea I'm running aida64, it's a benckmark stresstest for your CPU to test if you have a stable overclock... it's supposed to run at 100%
Then I'd suspect it's not making contact or you could have an issue with the thermal paste. I would do a sensor test first though.
Sensor test?
https://linustechtips.com/topic/460690-i7-4790k-oc-problem/#findComment-6182581
Either that or the fan. It may not be spinning at a faster rate while in load.
https://linustechtips.com/topic/460690-i7-4790k-oc-problem/#findComment-6182598
AIDA64 has one but I use TempGT to test the sensors, takes about 15min.
Seems like you need prime95 for that, and I heard that prime95 and i7 4790K aren't that good friends..
https://linustechtips.com/topic/460690-i7-4790k-oc-problem/#findComment-6182624
Yes, do not use prine95. Real temp is a great app, get it if only to get temps from multiple programs. I run it and Afterburner while I game to monitor everything.
Yea I got afterburner running all the time too.
https://linustechtips.com/topic/460690-i7-4790k-oc-problem/#findComment-6182677
