I heard it's pretty bad. Question is, will a H440 dust filter fit on it(I heard that one is pretty gopd) and vice versa?
i7 6700K @ Stock (Yes I know) ~~~ Corsair H80i GT ~~~ GIGABYTE G1 Gaming Z170X Gaming 7 ~~~ G. Skill Ripjaws V 2x8GB DDR4-2800 ~~~ EVGA ACX 3.0 GTX 1080 SC @ 2GHz ~~~ EVGA P2 850W 80+ Platinum ~~~ Samsung 850 EVO 500GB ~~~ Crucial MX200 250GB ~~~ Crucial M500 240GB ~~~ Phanteks Enthoo Luxe
https://linustechtips.com/topic/459586-s340-psu-filter/
The S340 PSU filter is absolutely fine and collects dust well.  Despite the recent review of the S340 Razer Edition, it's actually really easy to remove and place back the filter.
12600k | MSI MEG S280 | SSUPD Meshilicious | Asus ROG STRIX Z690-I | Crucial 16GB 4800MHz CL38 | MSI Gaming 980Ti | CM V850 SFX | WD SN850 1TB, WD SN550 1TB
Pi 4TB NAS | Asus VG27AQ, Asus PB278Q | Logitech G Pro X Superlight | Glorious G-HXL-STEALTH | Keychron K4 V2 | Sennheiser HD 599 w/ Fiio E10
https://linustechtips.com/topic/459586-s340-psu-filter/#findComment-6167331
How often should I take it out and clean it? If it helps I have an XFX XTR 750W.
https://linustechtips.com/topic/459586-s340-psu-filter/#findComment-6167336
as soon as it clogs up and performance is lowered
Considering my house, I'd say every 4 months. So is it just a slide out filter? I assume I could shake it outside and pull out particularly big pieces with my fingers.
https://linustechtips.com/topic/459586-s340-psu-filter/#findComment-6167352
Once a month?  Depends how dusty your room is.
https://linustechtips.com/topic/459586-s340-psu-filter/#findComment-6167387
I've got both cases. The filters are not interchangeable. They're very different.
The s340 filter fits under metal tabs on all of its sides. It doesn't slide out. You'll pretty much have to turn the case on its side to remove/replace it.
https://linustechtips.com/topic/459586-s340-psu-filter/#findComment-6171151
