so i got the hyperx clouds a couple months back and wasn't happy with the usb dongle as there was a static issue so i ordered a 4 pole to 3 pole splitter and an extension, so the splitter finally came in after a month so i wanted to test it out since it was a cheapo Chinese thing, so used my front panel audio and it works fine, sounds good my mic works, so i go to plug it into the mobo and now there a screeching noise, tried even without the splitter and same thing so my mobo audio jack is messed up. what should i do ? could i rma the mobo ? ( kinda dont want this options but i will do it for my ocd) or could i use another one of the jacks on the mobo and get the same thing ?
using the front panel audio is an option but actually one o the last ditch things cause id would have to have a cord coming off the top of my pc down onto my desk, across the desk and into my headphones which would look pretty bad.
i posted this in the mobo section and nobody replied so lets try the audio sectin, i really need to get this solved quick any response is appreciated
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/459219-audio-problem/
https://linustechtips.com/topic/459219-audio-problem/#findComment-6165892
It sounds like you already know a few potential solutions and just have to make a decision.
well none of the solutions except rma actually fix the problem, I don't want to rma the thing and someone says oh hey you could have just easily done this and it would have fixed it
and a car thread !
https://linustechtips.com/topic/459219-audio-problem/#findComment-6167103
Try to update your motherboard to the latest driver and go from there. Hope this helps!
i got a bit of homework, but i will try this as soon as im done ill let you know if it works
and a car thread !
https://linustechtips.com/topic/459219-audio-problem/#findComment-6171480
just updated it and its still doing it :/ im msging gigabyte and see what they say
and a car thread !
https://linustechtips.com/topic/459219-audio-problem/#findComment-6172849
