So I was wondering is this motherboard OCable?
http://pcpartpicker.com/p/jjMLmG
Nevermind, though it said z97, so i dont quite know.  However, there is a z97 asrock anniversary edition for a little more money.
Edited by Made In Canada
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/458780-first-build/#findComment-6156705
It isn't, since it is running the h97 Chipset. Try a Z97 one.
EDIT: I am not sure xD
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/458780-first-build/#findComment-6156707
Yes, but not official OC support so you might run into problems. Get a Z97 board instead.
My i5 6500 is bad and can't even maintain 4.5ghz, and 4.4ghz causes it to slowly become unstable over weeks with a vcore of 1.395. FML
https://linustechtips.com/topic/458780-first-build/#findComment-6156708
