Hello,
So basically, I have an old 9600 GT lying around and i want to install it in my rig, because it's better than my current 9500 GT. The problem is, the 9500 GT has a 50 Watts TDP and the 9600 GT has a 95 Watts TDP. I am running a Dell pc with the following specs:
  • Bestec ATX0300P5WB 300 Watts psu
  • Dell motherboard (don't know the name)
  • Intel Core2 Duo CPU E6550 @ 2.33GHz (2 CPUs), ~2.3GHz (not overclocked)
  • 4 dimms of 1 GB DDR2 RAM
  • Geforce 9500 GT
  • ASUS Xonar DG
  • 2 normal hard drives
  • 1 optical drive
  • Card reader
  • 3 fans
Will the psu be able to run the 9600GT in this configuration or do i need a bigger psu?
Thanks in advance!
Lizzard.
https://linustechtips.com/topic/45869-too-small-psu-wattage/
You should be fine, but I really wouldn't trust that power supply....
There's a time and place for everything! But not now. - Professor Oak
i7 2600K 4.3GHz  -  GTX 1060 3GB  - ASUS P8Z68-V - 16GB DDR3-1600 CL9 - EIZO 1080p 120Hz VA
Intel Skulltrail: 2x Core 2 Quad QX9775 - Intel D5400XS - 16GB FB DDR2-800 CL5 Quad Channel
EVGA SR-2 Classified - 2x Xeon X5675 4.2GHz - 24GB DDR3-1830 C10 Triple Channel
Intel Skulltrail #2: 2x Xeon E5472  - Intel D5400XS - 16GB FB DDR2-667 CL5 Quad Channel
https://linustechtips.com/topic/45869-too-small-psu-wattage/#findComment-603823
You'll be close to pushing the limits of that PSU (according to eXtreme Power Supply Calculator)
System Type:   1 physical CPU   Motherboard:   Regular - Desktop   CPU Socket:   Socket LGA 775   CPU:   Intel Core 2 Duo E6650 2330 MHz Conroe   CPU Utilization (TDP):   100% TDP           RAM:   4 Sticks DDR2 SDRAM   Video Card 1:   NVIDIA GeForce 9600 GT
        Regular SATA:   2 HDDs   Additional PCI Card (avg):   1 Card   Front Bay Card Reader:   Yes           Fans       High Performance:   3 Fans 120mm;             Keyboard and mouse:   Yes
System Load:   100 %               Minimum PSU Wattage:   270 Watts   Recommended Wattage:   320 Watts
Also, Bestec PSUs are not good, so I'd recommend upgrading.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/45869-too-small-psu-wattage/#findComment-603841
First of all, thanks for the quick answers. Is it a bad idea to just try it with the 9600 GT and buy a new psu if my current one fails, or will that destroy my other components aswell?
It won't destroy your psu. It just won't boot.
https://linustechtips.com/topic/45869-too-small-psu-wattage/#findComment-607867
