You're going to need to provide a lot more information if anyone is going to be able to help you.  What are the connection types you intend to use as inputs, and what is the final output you want to use. Also, budgets are helpful.
Main Rig:  CPU i5-4670k   MOBO Gigabyte Z97N-WIFI   GPU GTX 980ti    RAM 8GB  STORAGE 128GB ADATA(OS)/250GB Samsung 850 EVO(APPS)/3TB WD Red
AUDIO: AMP/DAC TEAC AI-301DA SPEAKERS: Cambridge Audio SX50 Phones: Philips Fidelio X1
https://linustechtips.com/topic/458348-iso-audio-output-mixer/#findComment-6156477
