PSU Wattage OVERKILL? Please help!
Solved by r1Ns3,
Your stuff is quiet nice, I like it.
As for your PSU, you should be fine with 500 watts.
It did include the gpu in the estimate and the estimate is pretty accurate.
A decent 500w is already plenty. 650w+ is pretty overkill.
The 550 G is an excellent option: http://au.pcpartpicker.com/part/seasonic-power-supply-ssr550rm
Alright, seems like thread is solved. going for 600 watts to support like a bunch more fans.
