Im planning to upgrade my pc cooling, my budget is around 60-70 euros.
so i can buy : - an all-in-one cooling kit with no additional fans ( 3 fans in total ( watercooling fan included)
                      - or i can buy an hyper 212 evo + 4 fans              ( 7 fans in total ( 212evo included)
my case is an aerocool xpredater x1 which support 3 x120mm in front , 2x120mm on top , 1 rear ( and 2x120mm on side but my gpu is to tall to mount fans there)
what would give me the best performance : air cooling or water cooling ?
my rig ( fx-8370@ 4.6GHz / Nepton 240m/ msi 970 gaming / 16 Gb corsair xms / antec VP700P /  aerocool xpredator x1 white / costum rgb lights / r9 290 direct cu2 / 1 TB hhd/ sandisk 128gb ssd / adata SP900 128gb )
peripherals ( steelseries apex / sharkoon fireglider black / razer goliathus / lg25ub55 )
https://linustechtips.com/topic/457040-air-vs-water-cooling/
It would help to list your specs.
Cooling affects temps but often not performance.
https://linustechtips.com/topic/457040-air-vs-water-cooling/#findComment-6157167
