Ok so I have been trying some overclocks in my GPU (STRIX 970) with MSI afterburner.
Following are the stock specs: post-252058-0-25113100-1443326106.jpg
At stock, I achieve a Min. FPS of 17, a Max. FPS of 51, and an average of 29 WITH A SCORE OF 1213 on the Valley Benchmark. post-252058-0-40269700-1443327039.jpg
This is how I overclock: post-252058-0-71943500-1443327089.jpg
I set leave the voltage alone, raise the power limit to 110% and add 100mhz to the clock.
The results are these: post-252058-0-46944600-1443327793.jpg
I dont know why the results are so insignificant, so i bumped up to to these specs: post-252058-0-60133800-1443328041.jpg
These are the results: post-252058-0-58276200-1443328430.jpg
Can somebody please explain and help me to achieve desired OC?
Thanks.
https://linustechtips.com/topic/456957-problems-with-gtx-970-oc/
Can you post screenshots of AB while running the test?  Restore everything to stock and try this guide.  http://linustechtips.com/main/topic/403328-nvidia-amd-graphics-card-overclocking-guide/
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/456957-problems-with-gtx-970-oc/#findComment-6132619
