At idle, yes it's supposed to underclock itself.
https://linustechtips.com/topic/456748-low-speed-cpu/#findComment-6128975
they drop down to that when they are at idle.. once you start doing stuff you will see it pick back up again
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/456748-low-speed-cpu/#findComment-6128979
It only uses what it needs, and will rise up when necessary
My Rig:
CPU: Intel i7 5820K @4.3 GHz; Mobo: MSI X99A SLI Plus; Cooler: Cryorig H5 Ultimate; RAM: 16GB HyperX Fury Black; GPU: MSI R9 380 4GB; Case: Fractal Design Define R5 Black w/ Window; SSD: Samsung 850 EVO 256GB and 500GB; HDD: WD Blue 1TB; PSU: EVGA 750W P2
Peripherals:
Monitor: LG 29UM57; Headset: HyperX Cloud II; Keyboard: Gamdias Hermes Mechanical; Mouse: Zowie EC2-A
https://linustechtips.com/topic/456748-low-speed-cpu/#findComment-6128986
As others have said, this is meant to happen. The CPU will run at a lower speed when under less load, dropping to it's lowest when idle. It will go up to the maximum speed when under enough load.
I believe this is called SpeedStep, but that term may be outdated now.
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/456748-low-speed-cpu/#findComment-6129059
If you want to disable this feature change your Power Plan to Performance mode.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/456748-low-speed-cpu/#findComment-6129098
