hd7770 bios problem
Go to solution Solved by Levent,
my mobo has pci-e 1x cant i just connect the gpu there just to flash and use my 8800gt as a primary gpu
yeah it might work try it
hey guys i need your help i flashed my hd 7770 to try to fix a problem i was having and now i cant boot the pc
the pc does the boot sound and the fans rev up and than stabilize like normal but the screen wont display a thing
i did a backup of the bios before flashing but i cant do a thing because my mobo doesn't have a on-board gpu and only has 1 pci-e 16x
what can i do to re-flash the bios?
Fx-8150 @ 4.7Ghz/Corsair h110/asus hd7770 1gb/Gigabyte 990fxa ud3/corsair xms3 4Gb 1333Mhz 8-8-8-20/WD scorpio black 250GB/hp w19ev/nox nx520/logitech access keyboard (y-sr34)/1life gm:lightning/
https://linustechtips.com/topic/45669-hd7770-bios-problem/
there is nothing you can do about it on your system you can try to flash stock bios on a motherboard with integrated graphics but i doubt it will work
https://linustechtips.com/topic/45669-hd7770-bios-problem/#findComment-601000
https://linustechtips.com/topic/45669-hd7770-bios-problem/#findComment-601016
https://linustechtips.com/topic/45669-hd7770-bios-problem/#findComment-601024
ok i will do it thanks XD
https://linustechtips.com/topic/45669-hd7770-bios-problem/#findComment-601027
i did it and it worked like a charm thx for the help
https://linustechtips.com/topic/45669-hd7770-bios-problem/#findComment-603003
