I want to get a heat sink and put on my own fans on it. Does the heat sink matter?
As in if I get a nh-d14 or some other heat sink will it make a difference if I change the fans to better ones anyway?
How much difference will there be in performance?
What heat sink do you think looks the best, for use with either corsair fans or ap15 fans?
Intel 4770k   -   Corsair Vengeance Pro CL9 16gb 1866mhz   -   Corsair Air 540   -   Gentle Typhoon AP45   -   Corsair ax1200i   -   Razer Death Adder 2013   -   Filco Majestouch 2   -   Crucial m4 256gb ssd   -   1TB Western Digital Black   -   Asus Maximus vi Formula   -   Bitspower matte black fittings   -   Black Ice sr1 240mm and 360mm Radiators   -   Swiftech mcp655   -   EK x-res pump top   -   Promochill Advanced lrt 3/8 5/8 bloodshed red tubing   -   swiftech apogee hd cpu block   -   Asus pb278q 1440p monitor   -   Razer Carcharas Headphones   -   Razer Vespula Hard Mouse Pad   -   Arctic Silver 5 TIM   -   Sapphire r9-290x   -   Ek-fc R9-290x Waterblock and Backplate
https://linustechtips.com/topic/45630-heatsink-without-fans/
I personally use a Coolermaster one with no fans on it.
[TRUENO] i7 4770k (~4.4Ghz, 1.28v) || Thermalright Macho 120 || Asus Z87 Gryphon || 2x8Gb Mushkin Blackline|| Reference NVIDIA GTX770 || Corsair Neutron GTX 480GB || 2x3TB WD HDD || Corsair 350D || Corsair RM750
https://linustechtips.com/topic/45630-heatsink-without-fans/#findComment-600360
Listen if you care.
https://linustechtips.com/topic/45630-heatsink-without-fans/#findComment-600361
I think you've missed the point he doesn't want passive he just wants to buy a heatsink and change the fans
and yes you can change the fans on a heatsink easily and I think the best looking heatsink is the silver arrow but thats just me
| 3570k @ 4.4.ghz | Hyper 212 evo | 8GB (2x4GB) 1600mhz Corsair Vengeance | Gigabyte Z77X UD3H | Corsair CX750M | Corsair 300R | OCZ 240GB SSD | Seagate 1TB 7200rpm HDD | Asus DCUII 7950 @1150mhz core 1600mhz mem
| BenQ XL2411T | Corsair Vengeance K60 | Logitech G700 | steelseries Qck+ | Fiio E10 | Zalman clip on mic | HD 598 | ATH-M50 |
https://linustechtips.com/topic/45630-heatsink-without-fans/#findComment-600528
Is there a large difference in between heat sinks?
For example, will an nh-d14 perform better then a Primotech Megahalem if they have the same fans?
I think the Megahalem looks good :)
https://linustechtips.com/topic/45630-heatsink-without-fans/#findComment-600560
Sicne you want your own fans, I guess you are going for a quiet build? If so, I highly reccomend you to have a look at the bequiet dark rock coolers. They are very good and the fans that come with them are excellent and VERY quiet. When you go with a cooler that has good fans bundled with it, you are getting more for your money, because then you aren't paying full price for the fans.
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
https://linustechtips.com/topic/45630-heatsink-without-fans/#findComment-602224
