Water Cooling?
Go to solution Solved by W-L,
So I was In science today and we were going over specific heat capacity. We went over oil and how it is much easier to heat up..
So I started thinking, wouldn't a PC Cool better with oil in stead of water so An oil cooling loop instead? Oil cools quicker than water, it absorbs heat quicker than water.
So what would happen If I put mineral oil or some other form of oil in a water cooling loop?
Please tell me if I'm wrong thinking this.
Cheers, Doug
it's more about mineral oil if your talking about that having a lower specific heat capacity and ability to hold as much heat as distilled water or cooling fluids, and the most difficult part is transferring that heat to the air through the rads for mineral oil.
Cheers, Doug
https://linustechtips.com/topic/456215-water-cooling/
bad idea... oil is thicker and would have a harder time getting through the small channels in the heat sinks, would make your pump work alot harder and probably burn out
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/456215-water-cooling/#findComment-6122519
It would eat the tubing
you would have to use hardline or copper ( it might still eat the hardline)
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
https://linustechtips.com/topic/456215-water-cooling/#findComment-6122545
Cheers, Doug
https://linustechtips.com/topic/456215-water-cooling/#findComment-6122584
