Noise in headphones
Pugsicle
So my graphics card emits a noise that seems like the fan since it is not high pitched like coil whine, and I can hear that noise in my headphones when I am playing games. Would a shielded sound card help eliminate this? The headphones are plugged in the ports directly on the motherboard in the back of my PC.
Coilwhine is not always super high pithced. For me it gets higher with FPS and acctualy starts pretty low frequency wise.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
It could be coil whine or it could be the cooler, either way its annoying that I can hear it in my headphones.
If I move my card to the bottom PCI express slot would that help at all?
Why don't you git it a try, hmm?
