which model of the MSI H97 your got?
is the LAN detected in the device manager?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/456068-msi-h97-internet-problem/#findComment-6120329
I have the gaming 3. I don't think it can detect it
look at the device manager and look for Realtek PCIe LAN or similar
if it not there
try to install the LAN drivers from the disc
https://linustechtips.com/topic/456068-msi-h97-internet-problem/#findComment-6120345
I don't have an optical drive could I get them with usb on a different computer?
Yes you could.
INTEL CORE i5-7600K | ASUS ROG STRIX B250i GAMING | CRUCIAL BALLISTIX SPORT LT 16GB | EVGA GTX 970 SC | EVGA B3 550W
SAMSUNG 850 EVO 250GB | CRYORIG M9i | BE QUIET! PURE WINGS 2| FRACTAL DESIGN DEFINE NANO S
https://linustechtips.com/topic/456068-msi-h97-internet-problem/#findComment-6120381
