Not really.
5400Rpm is quieter and slightly slower but not a big difference
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
is 7200 like the highest :o ? since i found a harddrive seagate desktop hdd 3 tb 7200rpm should i get it ?
The highest I've ever seen is 15,000rpm SCSI server drives. The fastest SATA drive I've seen is 10,000rpm WD Velociraptor series drives.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
is there a big differents between harddrive 5400 rpm and 7200rpm ?
Hey there :)
The RPM of a drive is just one of the factors that determine the performance of the drive. I would check the spec sheet of the drives that you are considering and check the actual transfer speeds that are described there. Generally, lower rpm means less performance but also less noise, vibration and heat output so it really depends on what you need from a drive.
For regular usage I can recommend checking out WD Blue, WD Black and WD Green:
WD Blue is your regular everyday drive that is most commonly used for regular computing, light gaming and workloads and combined with SSD. It is fully capable to run most games as well as many programs for editing or programming. http://products.wdc.com/support/kb.ashx?id=xebW08
WD Green is your energy-efficient drive that works cool, quiet and saves a lot of power. It is designed for backups and secondary storage. Its features allow it to be a great choice for quiet backup builds or for archiving. It is mostly chosen for massive media storage (up to 6TB) in builds that have another drive for the OS and active programs and games. http://products.wdc.com/support/kb.ashx?id=CMJERz
WD Black is the performance drive in WD's consumer line. It is the fastest among them and has good features such as a built-in dual-core CPU that makes the drive great for multitasking. It is designed for heavy gaming, big workloads and intensive file usage. It has a llong, 5-year limited warranty and its mostly used in gaming computers or editing machines. http://products.wdc.com/support/kb.ashx?id=LLtFSe
Feel free to ask if you happen to have questions :)
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
