So I am planning on starting to order pc parts this week, slowly but surely ordering them as I want to only by parts when they are on sale. Not sure how well that will work but what the hell.
http://pcpartpicker.com/user/Gigidy/saved/RVnV3C
This is what I have come up with. I changed the 380 to the 290 because with the current deals I could afford the extra $30. My question is will thag be worth it over the 380? Also how reliable is the MIR?
Also is the power supply enough? I chose it because I've heard xfx makes very high quality psu's?
In the spirit of MIR's how reliable are any of them? Because I would hate to go through the trouble and spend the extra money for nothing.
Thanks for replies guys! I love to hear from everyone! Any advice is good advice!
https://linustechtips.com/topic/454818-finalizing-pc-parts/
don't trust MIR
they are very shotty
you may never get your money
and if you do..it might be like 6 months later
main reason I never bother with them
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/454818-finalizing-pc-parts/#findComment-6101886
I've always turned MIRs off, I don't trust them, and there's no guarantee you'll actually get it in a reasonable time frame, if at all.
Build without them in mind, if it just so happens there are some, then consider it a (potential) bonus.
XFX is good, and the wattage is fine.
the parts in general are good, and dropping to a 380 if necessary wont hinder you too much.
Aftermarket 980Ti >= Fury X >= Reference 980Ti > Fury > 980 > 390X > 390 >= 970 380X > 380 >= 960 > 950 >= 370 > 750Ti = 360
"The Orange Box" || CPU: i5 4690k || RAM: Kingston Hyper X Fury 16GB || Case: Aerocool DS200 (Orange) || Cooler: Cryorig R1 Ultimate || Storage: Kingston SSDNow V300 240GB + WD Black 1TB || PSU: Corsair RM750 || Mobo: ASUS Z97-A || GPU: EVGA GTX 970 FTW+
"Unnamed Form Factor Switch" || CPU: i7 6700K || RAM: Kingston HyperX Fury 16GB || Case: Phanteks Enthoo Evolv Mini ITX (White) || Cooler: Cryorig R1 Ultimate (Green Cover) || Storage: Samsung 850 Evo 1TB || PSU: XFX XTR 550W || Mobo: ASUS Z170I Pro Gaming || GPU: EVGA GTX 970 FTW+
https://linustechtips.com/topic/454818-finalizing-pc-parts/#findComment-6101915
So turning off the MIR I would not be able to get the 290 would the 380 perform just as well or close to?
close enough, it'll manage 1080p60 on "High" or better in most games
https://linustechtips.com/topic/454818-finalizing-pc-parts/#findComment-6101989
404s, but what's your budget? and how much do you currently have?
https://linustechtips.com/topic/454818-finalizing-pc-parts/#findComment-6102819
So without MIR's I came up with this
http://pcpartpicker.com/user/Gigidy/saved/njX7YJ
I think it's pretty good but just one last check with you guys would be awesome
Seems fine, though I'm a fan of cooler master cases myself, and you probably don't need those fans and may want to go with this power supply, it's a bit more but it's modular which is super useful
https://pcpartpicker.com/part/rosewill-power-supply-hive550
https://linustechtips.com/topic/454818-finalizing-pc-parts/#findComment-6108102
