Please help! XD
Solved by KemoKa,
Found these instructions on another site.
First, yes,
1. You will need a repair disk. Have it on a USB drive or optical disc.
2: on the installation screen where it asks you to install windows, click on "Repair Your Computer" on the lower left corner of your screen
3: Now go to command prompt(It probably will show a window saying "Trying to repair windows automatically", close it) and type bootrec/fixmbr
4: after it finishes GRUB is gone and you can now boot into windows directly.
hopefully this works for you. If not, come back and we'll work something else out.
