So lately my wireless card or laptop i don't know, is playing up, not connecting to wireless networks correctly, taking forever to connect and always saying their limited untill 2 minutes after it tried it says their fine?
What i've tried:
deleting the driver and software
reinstalling the driver and software
both did nothing to help anyone else got anymore ideas please?
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/454302-intel-7260-issue-with-connection/
Reset your router...? Sometimes routers can take a while to connect & respond. This sometimes has to do with the beacon interval. Mine is set at 80ms.
How about updating the drivers? Make sure the antennas are connected correctly inside the laptop.
How do you plan on hacking the gibson if you can't even problem solve a little further? Disappointing...
blackshades on
plan on using a wired connection :P.
i might look at it, but i mean it does it at University as well which is what is strange,
i did try to look for a driver update so.
Current Build :
Laptop:
 CPU:
