CPU issue
Go to solution Solved by MegaDave91,
Clear CMOS by removing circular cell battery from the motherboard.
On my sabertooth z87 both dram/CPU led are lighting red after overclock.
Not posting and in endless reboot
Very unstable OC?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/453573-cpu-issue/#findComment-6083912
https://linustechtips.com/topic/453573-cpu-issue/#findComment-6083918
Attempted 4.7(at least I think I changed vus to 100 from default 125) on 1.2v
Ouch. Clear CMOS. Just turn your PSU off and remove the watch-sized battery.
https://linustechtips.com/topic/453573-cpu-issue/#findComment-6083928
You tried 4.7 GHz on 1V? Welp - that's a recipe for disaster if I've ever seen one.
https://linustechtips.com/topic/453573-cpu-issue/#findComment-6083962
1.2 trying to reset cmos
remove battery - wait 5 mins - return battery (while unplugged from wall)
https://linustechtips.com/topic/453573-cpu-issue/#findComment-6084004
