Quick, simple question about PCI-E lanes.
Go to solution Solved by 79wjd,
It will work (assuming you put the wifi card in one of the slots wired to the PCH).
So, I will soon have an SLI setup in my system along with a 1x PCI-E wireless card. The question is, will both GPUs still run at PCI-E 3.0 x8 since the PCH has it's own PCI-E lanes, or will I have to do something special with it for it to work?
https://linustechtips.com/topic/453568-quick-simple-question-about-pci-e-lanes/
PSU Tier List | CoC
Gaming Build | FreeNAS Server
How would I tell which slots are wired up to the PCH and which ones are not? The board is a GA-Z97X-Gaming 7 for reference.
x1 slots are wired through the PCH, full length slots are wired to the CPU in most cases.
Alrighty, thanks. I can't wait to build this thing :D
Just double check with the manual since sometimes motherboards are wired strangely. (I tried, but the manual is taking forever to load): http://download.gigabyte.us/FileList/Manual/mb_manual_ga-z97x-gaming7_e.pdf
Edit:
  • Expansion Slots 1 x PCI Express x16 slot, running at x16 (PCIEX16) *
    • For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
  • 1 x PCI Express x16 slot, running at x8 (PCIEX8) *
    • The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
  • 1 x PCI Express x16 slot, running at x4 (PCIEX4) *
    • The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode. *
    • When installing a x8 or above card in the PCIEX4 slot, make sure to set PCIE Slot Configuration (CPU) in BIOS Setup to x4. (Refer to Chapter 2, "BIOS Setup," "Peripherals," for more information.)
  • (The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.) 3 x PCI Express x1 slots (The PCI Express x1 slots conform to PCI Express 2.0 standard.)
  • 1 x PCI slot
PSU Tier List | CoC
I just stick mine in the top x1 slot assuming your motherboard has one, also keeps it away from the bottom of the GPU and just looks better IMO
A shadowy flight into the dangerous world of a man who does not exist.
Core 4 Quad Not Extreme, only available on LGA 557 at your local Circuit City
