Arkham Asylum Error? Help?
Go to solution Solved by Nineshadow,
Try running as admin.
I had an error while playing Arkham Knight and that fixed it for me. Maybe it will work here as well, but I doubt it.
Could not load file or assembly 'Microsoft.DirectX.Direct3D or one of its dependencies, Version=1.0.2902.0.The system cannot find the file specified.
Try reinstalling DirectX : http://www.microsoft.com/en-in/download/details.aspx?id=35
So I just downloaded Arkham Asylum on my PC and when I launch the game I get this error. Anyone know what the problem is? I installed the .net framework 4.6 after it couldn't install 3.5. Would that be the problem?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Could not load file or assembly 'Microsoft.DirectX.Direct3D, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35' or one of its dependencies. The system cannot find the file specified.
File name: 'Microsoft.DirectX.Direct3D, Version=1.0.2902.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35'
at BmLauncher.DisplaySettings.IsNVIDIACard()
at BmLauncher.Form1.Initialise()
at BmLauncher.Form1.OnLoad(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.8000 (FX35W81RTMGDR.050727-8000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
BmLauncher
Assembly Version: 1.0.1.0
Win32 Version: 1.0.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/Steam/steamapps/common/Batman%20Arkham%20Asylum%20GOTY/Binaries/BmLauncher.exe
Win32 Version: 2.0.50727.7905 (win9rel.050727-7900)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Management
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
BmLauncherUtils
Assembly Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Steam/steamapps/common/Batman%20Arkham%20Asylum%20GOTY/Binaries/BmLauncherUtils.DLL
msvcm80
Assembly Version: 8.0.50727.8428
Win32 Version: 8.00.50727.8428
CodeBase: file:///C:/WINDOWS/WinSxS/x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.8428_none_d08a11e2442dc25d/msvcm80.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
https://linustechtips.com/topic/452836-arkham-asylum-error-help/
https://linustechtips.com/topic/452836-arkham-asylum-error-help/#findComment-6073300
I reinstalled DirectX and it works perfectly! Thanks!
https://linustechtips.com/topic/452836-arkham-asylum-error-help/#findComment-6073370
No probs.
Have fun.
https://linustechtips.com/topic/452836-arkham-asylum-error-help/#findComment-6073377
