Not too confident about doing that. I'd end up breaking something.
then we cant help you
the sata cable might be unplugged or the sata power cable might be unplugged
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/452644-okay-my-hard-drive/#findComment-6070376
I see it in device manager, how do I 'mount' them?
Start up the partition manager, just go into Start and search for create and format partitions, and the option should show up.
Your hard drive should appear as an option there, and where your SSD has a blue stripe for its own partition, the HDD should be a black stripe, which stands for unmounted/unallocated space.
Right click on it and press "New Simple Volume". A setup "wizard" will appear. Keep clicking "Next" in the dialogue until it goes away.That will set whatever unallocated space you've selected to be a mounted volume, which will show up in your file explorer.
https://linustechtips.com/topic/452644-okay-my-hard-drive/#findComment-6070539
Start up the partition manager, just go into Start and search for create and manage partitions, and the option should show up. Your hard drive should appear as an option there, and where your SSD has a blue stripe for its own partition, the HDD should be a black stripe, which stands for unmounted/unallocated space. Right click on it and press "New Simple Volume"
Worked! thank you so much.
https://linustechtips.com/topic/452644-okay-my-hard-drive/#findComment-6070585
