Help! GPU usage idles at 85-89% :(
Go to solution Solved by Bananamancer,
Can you please show us the running tasks in task manager while selecting CPU usage apps to show first?
I was able to resolve it by finding the specific process that eats up my CPU usage and was able to track down the location and deleted the program. Thanks btw!  :)
Hi guys,
Please help me I don't know what to do. When I boot my pc I notice that my gpu is very loud.
When I opened Afterburner, that's when I saw that my GPU usage is always around 85-89% when I'm not even doing something.
I'm suspecting that this is a virus but how can I possibly clean my PC? I only have Microsoft Security Essentials and I already did a full scan but didn't find anything.
Please help!  :(  :(  :(  :(
CPU: Intel i5-4690K @ Stock | GPU: Zotac GTX 970 @ Stock | COOLER:Corsair H110i GT Stock fans | MOBO: Gigabyte Z97-X Gaming 5 | RAM: 2x4GB GSKILL RIPJAWS X 1866mhz PSU: Silverstone 500W Strider Essential Series | CASE: NZXT S340 | CASE FANS: x1 120mm TT Riing red LED, x1 140mm TT Riing red LED MOUSE: Razer DeathAdder Chroma & Logitech G502 Proteus Spectrum KEYBOARD: Varmilo VA87MR Gateron Red Switches | HEADSET: Logitech G230 | SSD: ADATA 256GB SP900 HDD: 500GB WD Blue & 1TB WD Caviar Black OS: Windows 10 | DISPLAYS: ASUS VX239H and some shitty Samsung 720p
https://linustechtips.com/topic/452549-help-gpu-usage-idles-at-85-89/
Do you mean CPU not GPU (GPU is your graphics cards proccessor). If its CPU open up task manager via the Ctrl+Alt+Delete menu and sort your processes by CPU usage to see which ones are at the top and post the process names here.
Thanks
CPU: Intel i7-4790K | GPU: Asus Strix 2080 Super OC | COOLER:Corsair H110i GT | MOBO: Asus Maximus VII Hero | RAM: 4x4GB Corsair Vengeance Pro 2133mhz PSU: Corsair RM 1000 | CASE: Corsair C70 | MOUSE: Corsair M95 KEYBOARD: Corsair K70 RGB SSD: Samsung 256GBx2 Raid0 | OS: Windows 10 | DISPLAY: Dell S3220dgf
Thanks
It's already indicated that it's my GPU not my CPU. I know some basics.
Sorry didnt mean to offend just wanted to double check  :)
Run malwarebytes first, full scan see if that detects anything if it does clean restart and see if that fixes it. If not i'd recommend removing the drivers for your card, re-seating it and reinstalling the drivers.
Will try this right now.
Might be some kind of malware miner or something.
Full malwarebytes scan as instructed above.
Case: Define R4 (Black - Window) | PSU: EVGA Supernova 850w Gold | Motherboard: ASUS Z97 Deluxe | SSD: Samsung 840 EVO (250GB) | CPU: Intel i7 4790K (Devil's Canyon) Delidded with CLU  GPU: ASUS STRIX 980 TI | Cooler: Corsair H100i with CLU | Extra: NZXT Hue
Already done with running full scan on malwarebytes but still my GPU usage idles around the same percentage  :(  :(  :(  :(
Thanks
And while I was monitoring things, I went to task manager and saw that my CPU usage is also around 50-60% when I only opening chrome and afterburner  :(  :(
Did that resolve the GPU usage aswell?
Yep it did  :)  :)
Yep it did  :)  :)
Great! You can mark this as solved.
Quick question for future reference, what was the process?
Yep it did  :)  :)
Great news  :D
It was some sort of a miner.
