Help me build a PC
Go to solution Solved by sohelshaikh97,
this if you're fine with 2tb of storage (you can add more wherever you want anyway)
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
Motherboard: Asus H97M-E Micro ATX LGA1150 Motherboard  ($94.27 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.49 @ OutletPC)
Video Card: EVGA GeForce GTX 750 Ti 2GB Video Card  ($124.41 @ Mac Mall)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($35.99 @ SuperBiiz)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($89.88 @ OutletPC)
Monitor: ViewSonic VA2349S 60Hz 23.0" Monitor  ($136.99 @ Amazon)
Total: $998.89
Generated by PCPartPicker 2015-09-18 13:02 EDT-0400
and this if you aren't
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard  ($79.89 @ OutletPC)
Video Card: Zotac GeForce GTX 750 1GB ZONE Video Card  ($77.98 @ Newegg)
Total: $1005.97
Generated by PCPartPicker 2015-09-18 13:06 EDT-0400
can i get a 4k monitor?
Yes, I wanna assemble a PC. I am totally noob to this.
Usage:
Not a gamer but play games like Counter Strike once in a while. High end gaming isn't my thing.
I am into programming and web developing. I use android studio, Photoshop and other adobe software very frequently.
Watching videos and surfing internet is in considerably high amount so I need storage. Tell me cheapest I can buy with capacity around 4tb or less.
Budget:1000$
https://linustechtips.com/topic/452110-help-me-build-a-pc/
Do you need a monitor and OS? and i dont think you need to spend 1000...
actually now that im thinking about yea 1000 is a good budget for that
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062233
Yes I need an OS.
so no monitor?
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062255
Also I need monitor, CPU cabinet, mouse, keyboard.
lucky for you, i've been working on my own with similar need but more towards a gaming need, here this is an edited version of it also you can remove the SSD and get a larger HDD if you wantPCPartPicker part list / Price breakdown by merchant
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($71.98 @ Newegg)
Memory: Team Elite 8GB (1 x 8GB) DDR3-1600 Memory  ($35.99 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($84.95 @ Amazon)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($44.75 @ Amazon)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply  ($44.99 @ NCIX US)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  ($32.99 @ Amazon)
Monitor: Acer G226HQLBbd 60Hz 21.5" Monitor  ($90.00 @ Newegg)
Other: Windows 10 from reddit ($50.00)
Total: $990.47
Generated by PCPartPicker 2015-09-18 12:45 EDT-0400
My system is the Dell Inspiron 15 5559 Microsoft Signature Edition
                         The Austrailian king of LTT said that I'm awesome and a funny guy. the greatest psu list known to man DDR3 ram guide
        i got 477 posts in my first 30 days on LinusTechTips.com
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062276
Hows this?
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor  ($183.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard  ($83.89 @ OutletPC)
Video Card: MSI Radeon R9 380 2GB Video Card  ($184.98 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($16.59 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($97.89 @ OutletPC)
Total: $930.20
Generated by PCPartPicker 2015-09-18 12:47 EDT-0400
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062289
oh oops
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062295
Total: $823.92
Generated by PCPartPicker 2015-09-18 12:49 EDT-0400
here, no need to spend 1000$ on it - in fact this is probably more than you need already, but since you have the money might as well make it great amirite?
unless you need a monitor and os with it too - then that may not fit in the leftover money, if that's the case tell me and I'll make a cheaper build
sudo chmod -R 000 /*
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062315
Total: $823.92
yes i need a monitor and all other peripherals: mouse keyboard
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062372
Total: $998.89
Total: $1005.97
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062413
Total: $998.89
Total: $1005.97
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062443
With what money? Those are 450$ and up. To afford one with your budget you'd need to drop the dedicated gpu, downgrade the cpu and give up the two hard disks or a hard disk and the ssd. At which point you wouldn't have sufficient performance for playing games and your productivity would suffer as well.
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062471
so 1080 is good enough or should i increase my budget?
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062493
That's up to you. It's very subjective based on the window sizes you like to use with your software.
If you've used 1080 before, a good thing to ask yourself is if you'd prefer larger windows and see more of your content when you have the windows full-screen.
Edit // Food for thought:  I just saw this in the Hot Deals section.  It's factory refurbished. But it's Samsung, so it's solid.
http://sellout.woot.com/offers/samsung-28-4k-led-backlit-monitor-42?ref=cnt_dly_tl
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062557
As @watts300 said, it's entirely up to you. 4k is godsend for this sort of work, but that carries a cost. If you think you can work well enough with a 1080p monitor, then spare your money and jump to 4k when the prices drop under 250$. If instead you really want the surface area, all you need to do is shell out another 300$. Bare in mind however that the 750/ti doesn't have a displayport port, so you'll need to go for a different graphics card (specifically an amd one, anything inbetween the r7 250x and r9 270 will do just fine).
https://linustechtips.com/topic/452110-help-me-build-a-pc/#findComment-6062920
