fak R9 390 help
Muz
So I just got my R9 390 today, and every things been fine, but sometimes (Only happend twice in the past 4 hours.) my PC will completely freeze, just a still image on the monitor and I can't move my mouse or w/e until I restart it, and this has only happened after I installed the Gigabyte R9 390 today, can I get some help to help me solve this? Should I RMA?
I have latest drivers etc etc.
- CPU: Intel i7 3770 - GPU: MSI R9 390 - RAM: 16GB of DDR3 - SSD: Crucial BX100 - HDD: Seagate Barracuda 1TB -
RMA
REDLINECore i7 6700k 4.8ghz 1.37v.Noctua NH-u12s.MSI Z170A Gaming M7.16GB Kingston Hyper X Fury Black.MSI Gaming R9 390 8GB Crossfire + GTX 780 PhysX.Samsung EVO 850 500GB SSD.Fractal Design Define R5 Midi Black.SeaSonic X Series 1050w Gold.Logitech G302 Deadalus Prime.Ducky DK2108 Zero Mech Cherry Blue.
RMA
RMA RMA RMA NOW!!!!! (O_O)
wait..... is it stock clocks or are you OC'g, if so then run @ stock to see if issues clear
if you are not OC'g then refer to my first answer :D
CD driver?
Well, I would at least try installing the different drivers (if you are on the latest beta, try one before it) first before RMA'ing it. Could be a problem with something else, not the GPU.
edit
edit
I was on the latest official one, trying latest beta now though.
Just be sure to unisntall the previous one, delete the folder (if necessary), reboot and attempt the install.  I found that to be the only way to get the drivers to work for my brothers' 280s, might work for you. If not, definitely start the RMA process immediately.
Now I wait to see if it happens again with these drivers.
Btw, can list your spec? proc, PSU model, etc.
Intel i7 3770
GA-B75M-D3H
Thermaltake Smart 750w
Gigabyte R9 390
16GB of DDR3
