1. This is my first post on these forums. (Yay!)
2. I'm also on pcpartpicker. (Same name)
3. https://pcpartpicker.com/b/LHtJ7P
4. I want to mod my s340.
I was thinking about cutting some shapes into the front panel, unscrewing the metal from the plastic, putting a thin cloth material in between and screwing it back together. I was thinking this could help improve airflow a bit and just look better. Also, I wanted to paint my pci covers and the tips of some thumbscrews.
I already know I should:
1. Measure multiple times and make sure it's right
2. Put masking tape or something over the surface I'm cutting.
3. Have a sketch of the front panel.
4. Sand what I'm painting.
The reason I came here is because I want to know if there is anything else I should know before doing this. Help would be appreciated for my first mod on my first build.
https://linustechtips.com/topic/451245-s340-modding-first-mod-too/
-SNIP-
Welcome to the Fourms!
Sounds like a good start, a quick tip when cutting say with a dremel or any tool be sure to cut away from your final line and afterwards use a file to file the material until you meet the line to get perfectly straight cuts or even curves.
If your interested I have a write up here on a bunch of different things from General Painting and techniques to diagrams on here:
http://linustechtips.com/main/topic/407754-modding-faq-common-mods/
It's not necessary for the sake of airflow.  I have an S340 and I did a little experiment to see.
I recorded before I stressed the GPU. But it also peaked at 70C.
