So i have a dual 180mm rad, how much thermal capacity does it have?
180x460mm, and 35mm thick, and copper.
How many parts could I have on it?
It should be about the same as 5.75 120mm rads, right?
https://linustechtips.com/topic/451226-how-much-thermal-capacity/
which 180mm rad is it
main rig
 corsair 750d | evga 1000w g2 | Gigabyte x99 soc champ | 5820k 4.0GHz | 1tb wd blue | 250gb samsung 840 evo  | Crucial Ballistix Sport XT 16GB 8x2 DDR4-2400 | MSI GTX 970 x2 | monitor Acer B286HK 28" 4K | razor chroma blackwidow  | razor death adder chroma
CENTOS 7 SERVER (PLEX&docker stuff)
NZXT s220 | evga 500w 80+ | AMD FX 8320e | ASUS M5A78L-M/USB3 | 2x8gb non ecc ddr3 WD red 2TBx2 | seagate 160gb microcenter 8gb flashdrive OS
I'd probably say it has around the cooling capacity of a 45mm thick 360mm radiator approx. you can for sure do a CPU and GPU both overclocked on that with something like a good pair of pressure optimized EKWB or silverstone fans.
