Best thing would be you figure out the peripherals beforehand and work with whats left, those vary a lot in price.
Your pc budged is gonna be a bit low if you spend 200$ on other stuff though, so maybe you should look at some used parts.
Do you also need windows? Do you have any older parts you can use?
https://linustechtips.com/topic/450847-600build-guide/#findComment-6044948
Im assuming you don't need a OS because you didn't say to include on
CPU: Intel Core i3-4160 3.6GHz Dual-Core Processor ($112.89 @ OutletPC)
Motherboard: Asus H81M-D PLUS Micro ATX LGA1150 Motherboard ($49.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 8GB (1 x 8GB) DDR3-1600 Memory ($38.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.99 @ Amazon)
Video Card: EVGA GeForce GTX 950 2GB Superclocked+ ACX 2.0 Video Card ($149.99 @ Newegg)
Case: Thermaltake Versa H22 ATX Mid Tower Case ($33.99 @ SuperBiiz)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply ($29.99 @ NCIX US)
Monitor: Acer S220HQLAbd 60Hz 21.5" Monitor ($99.99 @ Amazon)
Keyboard: Cooler Master OCTANE Wired Gaming Keyboard w/Optical Mouse ($43.99 @ NCIX US)
Total: $606.81
Generated by PCPartPicker 2015-09-16 06:34 EDT-0400
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/450847-600build-guide/#findComment-6045027
