Hey everyone,
Im buying a genuine oem battery that is brand new in the package. It was manufactured on 2014/05. Will the battery have degraded by a sogificant amount from then till now?
R5 5600   Asus ROG Strix RTX2060   B550  Crucial Ballistix 16GB DDR4   Kingston A2000 1TB M.2    Kingston UV400 SSD   NZXT H510 Flow
https://linustechtips.com/topic/450785-battery-degration/
depends on the conditions it was stored in
Lets say good conditions that suit the battery, and then stored in a back room for a few months after that
https://linustechtips.com/topic/450785-battery-degration/#findComment-6044251
Most batteries as long as they are kept at about 50% charge or at least above the safe lower limit of their charge will be good just sitting in a properly temperature controlled room for a couple of years. The voltage will slowly start to drop so after a certain period of time they can just go bad once they drop past that lower limit for too long.
https://linustechtips.com/topic/450785-battery-degration/#findComment-6044291
Ok thanks, brought the battery since i shorted my usb and caused my current battery to be damaged.
https://linustechtips.com/topic/450785-battery-degration/#findComment-6045132
