Mini ITX build under $600
Go to solution Solved by Jvagle875,
Well I was also thinking about waiting until the 9000 series gpus are released and I thought that an APU would suffice until then. What do you think about that? A 5800k and some fast ram should play games on low well enough right?
It should do alright, If you plan on doing a new system in the fall, then I'd say that that would be a decent enough placeholder. Just bring down the resolution to 720p and it'll be alright. Just be realistic with your performance expectations. Maybe grab a decent case and PSU that way you can keep those for the new system?
Hello. So I was wondering if it would be a bad idea to do a build like this: http://pcpartpicker.com/p/1qQBU
I want to do a small build so it is more mobile and the prodigy is so cool.
Are there any concerns/changes/recommendations you may have for me?
Purpose: Gaming
Price: under $600
Form Factor: ITX
Performance: Amazing for price
FX 6300 - MSI 7870 Ghz - M5A97 R2.0 - Team Vulcan 8GB - WD Caviar Blue 1TB - Rosewill HIVE 550w - NZXT Source 210 (white) - Loud Fans
Peripherals - Logitech G105 - Cobra mouse - Acer G236HL - Logitech desktop mic - Logitech LS21 - Audio Technica ATH-M30
Laptop - Acer Aspire V3 - A84500m - 7670m - 15.6" screen (1366x768) - 3.5GB DDR3  - 500GB Scorpio Blue
https://linustechtips.com/topic/45064-mini-itx-build-under-600/
it works, but WHY, if you are getting a dedicated graphics card, there is no need for a APU, just go and get the FX 6300 or a phenom if you want the FM2 board
also, get a tad bigger of a PSU
thanks for the build idea, totally going to steal it :P
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592015
prodigy isn't small XD
Get a richland 6800K with 2133MHz+ memory and add a graphics card later.
Available from 3pm to Midnight Eastern Time (GMT-5). (>'-')> <('-'<) ^(' - ')^ <('-'<) (>'-')> You can't stop the kirby dance.
4770k | Gigabyte GTX 970 Mini | Lian Li PC-TU100B | MSI Z87I 2x8GB G.Skill Sniper | Noctua NH-L9i Silverstone Strider 450W SFX | Windows 10 | 2x 250GB 840 Evo Rad 0 1x 1TB WD 2.5" | 25% gaming, 25% CAD and rendering, and 50% web browsing.
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592020
he's got $600, just go with the dedicated graphics and a phenom
It's better he goes with higher quality parts now, and then saves up for a nice 760 later ~
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592033
makes no sense, phenoms are highly overclockable and they are very good, can beat an i3 when overclocked, it's much better, APU's are for bottom of the bottom gaming, he clearly has cash for a HD 7870
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592038
There is no Mini ITX AM3+ boards
OS - Windows 8.1 Motherboard - ASUS M5A99FX Pro R2.0 Processor - AMD FX 8350 Black Edition RAM - 16GB 2x8 Crucial Ballistix Sport Graphics Card - Gigabyte Windforce 2 OC GTX 660 Power Supply - Corsair CX750M CPU Cooler - NZXT Kraken X60 Wireless Adapter - ASUS PCE-N15 PCI-E Adapter Fans - x3 Masscool blue LED 120mm Fans Case - Fractal Design Define R4
Monitor - Dell S2230MX 21.5-inch Keyboard - Logitech G105 Mouse - Logitech G602 Speakers - Logitech Z130 Headsets/Headphones - Tt eSports Shock, AKG K240, California Headphones Laredo Phone - iPhone 4S
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592039
I am only thinking of getting an APU because it is the only cost effective way of getting a mini ITX motherboard. The athlon 750k performs worse.
Dont use stock CPU cooler. Just because its not as cool. :D
Believe me I will find a better one
I know prodigy isnt that small but they just look too sweet to pass up.
I would in a heartbeat if I could get it in a mini ITX version.
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592041
that's why I said "phenom if you want the FM2 board" :P
dude, Phenom is on that platform...
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592044
I just retired an A10 5800k APU that I paired up with a 7870 and can 100 percent say that while it was a good little rig, It really really fell behind in terms of CPU performance. If your getting a dedicated card straight up look at something that isn't in the APU line. Perhaps even an i3 as it will have a bit more power in terms of the CPU
So you think I would be better off with like an i3-3220? Since it is hyper threaded it performs like a quad core right?
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592045
Phenom is not on FM2. It IS on AM2 which may have you confused..
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592047
Pretty much mate, Maybe even wait a little for the Haswell i3's to make it to the market
I looked at a comparison on cpuboss.com  and the i3 3220 only wins in single core performance. (http://cpuboss.com/cpus/Intel-Core-i3-3220-vs-AMD-A8-6600K)
And it is not unlocked.
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592068
http://pcpartpicker.com/p/1qYdG
A little over on price, something to consider.
[TRUENO] i7 4770k (~4.4Ghz, 1.28v) || Thermalright Macho 120 || Asus Z87 Gryphon || 2x8Gb Mushkin Blackline|| Reference NVIDIA GTX770 || Corsair Neutron GTX 480GB || 2x3TB WD HDD || Corsair 350D || Corsair RM750
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592076
http://pcpartpicker.com/parts/partlist/
You have to use the permalink for others to see it.
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592101
How about something like this? It's a little bit over 600 but I think it'd give you some solid performance. http://pcpartpicker.com/p/1qYrf
If 600 is a firm price, http://pcpartpicker.com/p/1qYtL There is 30$ in MIR's. Otherwise grab a 7770 and call it a day.
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592123
Why should I spend $74.99 on a 450W PSU from Seasonic when I can get a 500W PSU from Corsair (Seasonic is the manufacturer) for $39.99 ?
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592136
Fair question. To me, the 80+ Gold rating does it. But that's just my opinion. Is Seasonic the manufacturer for all of Corsair's PSU's? I didn't think so, but I very well could be wrong. But if you'd rather go for the Corsair and spend the money elsewhere, that's alright too, both are good PSU's, that's just my preference.
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592156
I would spend more on the PSU if I had a bigger budget. But being on such a tight budget I really have to save money wherever I can.
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592163
http://pcpartpicker.com/p/1qYKR
Just take the 20 MIR on the PSU and get a 7850  :)
Will this build yield better performance in games? Considering that the GPU is more important why should I downgrade it in favor of an equally performing CPU?
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592188
The difference between games might be slightly noticeable, but if you use the FM2 platform, you're stuck. Where as with the 1155 platform, there at least is a springboard for future upgrades. And to be honest, I'm not sure I would consider an A8 an equally performing CPU.
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592265
That is a valid point. Is there any word on Haswell i3's release date?
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592300
Can you stretch you budget just a bit?
http://pcpartpicker.com/p/1qZxR
https://linustechtips.com/topic/45064-mini-itx-build-under-600/#findComment-592310
