My old pc has a 275w psu, I recently added a Geforce GT 520 because 1080p videos lagged out on the integrated graphics. After that my computer is beginning to Blue Screen and just shut off.
Temps:
CPU: 33C idle / 65C load
GPU: 60C idle / 75C load
Specs:
Athlon || x4 2.7 ghz
stock 275w psu
6gb ddr2 ram
geforce 9100 integrated graphics (disabled)
Zotac 1gb gt 520
I've basically figured that it must be a PSU issue. But could there be something that I'm missing? I don't want to buy a psu and have my pc still keep blue screening.
Another weird thing is that at load it doesn't blue screen, it only does it at idle..
Thoughts?  :huh:
https://linustechtips.com/topic/45050-blue-screening-help/
Try to take gpu out and see if blue screen goes away, then you know gpu is dud or psu can not power it.
Desk: monitors 3x Asus VE248h(eyefinity), Keyboard Cm Strom Trigger(mx red), Mouse Corsair m65, Headset Audio Technica ATH-M50
Black Friday 2013 Build: i7 4770k, Gigabyte Z87X UD5H, 16gb Corsair, Msi R9 290, Corsair Axi 760, Corsair 750D, 2x intel 530 240gb ssd, 2x Seagate 400gb
Older Machine amd x640, msi 760g mobo, 8gb gskillz, Sapphire 6870, Corsair hx650, Cooler master haf 922, ocz agility 3 120gb ssd || HTPC: i7 3770k, shuttle xpc z77, 16gb gskillz, Asus GTX 650 ti, intel 120gb msata ssd
https://linustechtips.com/topic/45050-blue-screening-help/#findComment-591722
The PSU seems a little underpowered but what I'd do first is download BlueScreenViewer and see what the memory dumps have to say for themselves
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/45050-blue-screening-help/#findComment-591737
The graphics card works perfectly, is there another way it could be a "dud"?
Most likely the psu, try a clean install of windows.
Its a clean install since 4 days ago.
https://linustechtips.com/topic/45050-blue-screening-help/#findComment-591740
Can you try the gpu in a different system or do a test with no gpu. Then you can narrow it down to psu delivery or gpu dud. Also pci lane of mobo could be bad and causes the machine to bluescreen I had this issue with an asus mobo and it caused me some serous problems. Is there another pci express lane to try?
https://linustechtips.com/topic/45050-blue-screening-help/#findComment-591761
Only one open lane unfortunately, I'm going to run no card for about a week and see what happens..
https://linustechtips.com/topic/45050-blue-screening-help/#findComment-591776
Power supply likely can't support it power wise, if it's just a cheapy power supply the rail(s) might be too weak, 275w is low
Case: NZXT H440 | CPU: i5 4670K @ 4.5 GHz | GPU: MSI 970, Kraken G10 | Mobo: ASRock Z97 Extreme3 | Cooler: H100i | PSU: Corsair AX750 w/ Sleeved Cables | Display: 3xBenQ RL2455M | Fans: 5xNoctua NF-F12, 1xBitFenix Spectre |
https://linustechtips.com/topic/45050-blue-screening-help/#findComment-591817
Hopefully it will work normally. If that is so, try to run the card in a friends computer or another computer you own and see if it blue screens. If it does, then the gpu is the issue, if not then it is psu or mobo related. To test the motherboard try a friends gpu in it and see if it causes the machine to crash.
https://linustechtips.com/topic/45050-blue-screening-help/#findComment-591847
